620 throttle and PTO Clutch
Jeff J.
04-30-2004 16:17:46
Recently got a 620 tractor, the throttle lever continually slips back to slow, to use the tractor I have to hold the lever all the way forward. Did not see an easy adjustment but then its all new to me. Any suggestions?? Also, when using the PTO the pto shaft runs continually. The Pto clutch does not make any difference if engaged or disengaged. Is there a simple adjustment or is this a big job to fix.
Thanks for any help.
Hillbilly in Vegas
05-01-2004 12:02:50
 Re: 620 throttle and PTO Clutch in reply to Jeff J., 04-30-2004 16:17:46
I hope you're enjoying your 620. I've got one and they are very good tractors. Anyway, I have not encountered the throttle problem myself, but if you search the archives, you'll find some posts on the subject. On the PTO shaft spinning, the PTO brake probably needs adjusting and it's a fairly easy job. From the 620 operators manual - "The operating rod that attaches to the PTO clutch pedal has a yoke on the opposite end that attaches to the PTO fork shaft arm. Disconnect the yoke on the rear end of the operating rod and loosen the jam nut. Turn the yoke 1/2 turn at a time to shorten the operating rod, until the powershaft stops when clutch is disengaged and pedal latched." I like to make the brake adjustment with the tractor running and no implement attached to the PTO shaft. To do this adjustment with the tractor running, make sure you lock the brakes down, put the transmission in nuetral and fully engage the hand clutch.
