720LP Head Block Dimensions
Bob K
04-30-2004 07:02:57
I suspect the previous owner of my 720LP shaved either the head or the top of the block to increase power for pulling at shows. I know this because nearly all the adjustment of the rocker arms is taken up to get the .020 gap with the valves closed. It fires hot (burns off high-heat manifold paint on the exhaust pipe and muffler)and pops very loud. It's a little difficult to start, runs smoothly, but doesn't have a lot of low-end power (I suspect the regulator needs overhauled). It's ironic that it's been messed with to increase power, but doesn't put much to the wheels. It sounds like it could drag Texas into the Gulf, but can hardly pull itself up a hill in the pasture.
Where can I get factory head thickness and block dimensions so I can see if mine have been modified? Can someone out there measure their stock head or block to give me a reference? I haven't measured the cam yet, but most of that info is in my service manual. Thanks.
Ben.So.Tex
05-01-2004 11:56:48
 Re: 720LP Head Block Dimensions in reply to Bob K, 04-30-2004 07:02:57
Try turning the load neddle on the carb out alittle. My 730lp would start, but could not pull its own weight in 3 gear when I got it, so one of the many good friends here on the site told me to do this and it works fine now. the neddle is on top of the carb and has a roll pin in it just open it up an see what happen. Good Luck Ben
buickanddeere
04-30-2004 14:24:07
Before tearing it apart, try setting the mixture and timing on a dyno. After ensuring the LP and ignition systems are in tip top shape. Somebody with tinkeritous may have the timing way advanced and the LP pressure too high.
