Russ, I agree with Pappy.. By far the leading cause of having to pull a plug wire partially off a spark plug to get it to run on a cylinder is a fouled or partially fouled spark plug.. Did you install brand new spark plugs or a used spark plug? If new spark plugs were installed then the first thing to try is simply swapping the spark plugs from side to side, if that helps the poor running side then you either have another fouled spark plug or you installed a defective plug.. ~What happens when you pull that plug wire partially off the plugs is: It puts a spark gap in the secondary ignition side that is greater than the spark plug gap so the secondary KV has to build higher before jumping that added larger gap, when it builds high enough to jump that added gap it then has no problem jumping the plug gap even if it�s partially fouled.. Without that added gap the KV developed by the ignition coil can bleed off through the plug fouling & never build high enough to jump the plug gap.. That extra gap has nothing to do with delayed spark as the spark timing is controlled by the distributor, it has to do with spark intensity. ~If swapping the spark plug makes no difference then you have other problems like low power to the ignition coil, or a lean #2 cylinder, or a carb internal metering problem, or even vacuum leak on the non firing side [that�s usually only an idle problem though].. ~What spark plugs are you using? Usually changing to a hotter plug [like a D-21 or D-23 or equivalent ] will eliminate a plug fouling problem.. The modern no-lead emission gasoline seems to require a hotter plug to function properly under light load conditions.. If you are using a lead substitute that can also lead to plug fouling & problems like you are experiencing.. ~If a new spark plug helps for a while then you might want to check your air cleaner for water or crud in the bowl & maybe even pull the entire air cleaner canister & have it boiled out.. A plugged [partially plugged anyhow] air cleaner is a fairly common problem & can cause all kinds of plug fouling problems.. ~If adding that extra gap in the secondary by partially pulling a plug wire improves a cylinder firing that usually means you have a decent working ignition system but it wouldn�t hurt to check it� To do that just take a [KNOWN GOOD] spark plug [it doesn�t have to be for your tractor], then open the plug gap to 3/16�, then install that in one plug wire at a time & lay on the engine block, now crank [or run] the engine�. You need to see a bluish spark jump the plug gap EVERYTIME that side is supposed to fire.. If the spark is yellowish or erratic you probably have ignition problems.. ~Seeing as you have a solid state ignition system you can run a high output coil & that in itself can help.. You might call the company that you bought the solid state ignition from & ask what high output coil they recommend.. ~On you flywheel TDC problem� You can remove both spark plugs, then turn the flywheel until it is close to your estimated TDC, then reach in the L/H spark plug hole with a pencil or wire & turn the flywheel until it touches the pencil or wire.. Then put a mark on the flywheel hub bottom that lines up with the dimple in the lower center of the flywheel cover hole.. Now turn the flywheel the other direction & do the same thing.. 1/2 way between those marks is the true TDC.. If your flywheel is on correctly the flywheel slot should be running directly fore/aft at TDC.. [email protected]
