LumbrJakMan, the operators manual suggested initial settings are: On the idle screws [those are the T shaped screws sticking out the bottom of the carb].. Turn them both in until lightly seated then back them each out 1-1/2 turns.. On the load screw [bigger recessed screw on the bottom of the float bowl] turn it in until lightly seated then back it out 2-1/4 turns.. ~To do a running adjustment on the idle screws.. First make sure the exhaust manifold heat valve is set proper for the weather in your area [it should be set to cold for the summer],, then start the tractor & run until hot,, then use a rubber band or your hand & hold the carb throttle lever against the throttle stop,, then set the idle stop screw up so you have about a 600 RPM idle speed [that�s so the governor doesn�t keep changing the idle speed as you adjust the carb],, then use a jumper wire & paper clip & short out one spark plug wire [DON�T JUST PULL A PLUG WIRE OFF AS THAT CAN DAMAGE THE IGNITION SYSTEM],, then set the idle needle on the OPPOSITE side for fastest idle speed,, then remove that plug wire shorting jumper & short out the other plug wire & adjust the other side to fastest idle speed.. You might have to give & take a little to get both sides to idle about the same speed but try to get them as high & close as possible.. When all set & done re-set the base idle to 300 RPM then remove the rubber band [or put the screw back where it was].. ~To set the load needle you really should do that under a load but can get it close statically by using the throttle lever.. To do that, just let the engine idle for a short while then briskly advance the hand throttle.. When that load needle is close it should take the brisk throttle advance smoothly with no backfiring or popping [a little black smoke from the muffler is normal on throttle up].. If it pops or mis-fires on fast throttle up then open the load needle about � turn more & try it again, keep opening the load needle until it takes the throttle smoothly.. That might leave the load needle slightly rich but unless you are going for max fuel economy it will be good to go there.. Any questions just post back or E-Mail� [email protected]
