1950 B timing gear
coach
04-29-2004 13:15:12
I was wondering if the crankshaft timing gear should have a "v" timing mark or a dot. cam and govenor have v timing marks but cant find one on crank, just a single dot on the inside of gear is this it?
WTW
04-29-2004 13:33:20
 Re: 1950 B timing gear in reply to coach, 04-29-2004 13:15:12
Yes, The cam to crank timing marks do exist just like the cam to governor marks only the marks for the cam to crank are on the opposite side of the cam gear. Marks are viewed by looking down through top cover hole of crankcase. They are there just keep looking. Dave W.
coach
04-30-2004 06:58:43
 Re: Re: 1950 B timing gear in reply to WTW, 04-29-2004 13:33:20
Dave, I have the crank out of the block and cant find the v mark, but there is a mark in the form of a dot that looks like somebody took a punch to it on the inside of the gear. Could this be an aftermarket gear that might not of had the same type of timing mark? Or maybe it is where the gear is close to the crank and i cant see it. Thanks for the help
WTW
04-30-2004 11:02:46
 Re: Re: Re: 1950 B timing gear in reply to coach, 04-30-2004 06:58:43
coach, The mark on the inside of the crank gear is your mark to time your cam to. There will be another possibly two on the inside of the cam gear to match to crank gear mark. The marks on the opposite side of cam gear are to time governor only. When you get to cleaning you will find them. Dave W.
coach
04-30-2004 12:22:26
 Re: Re: Re: Re: 1950 B timing gear in reply to WTW, 04-30-2004 11:02:46
Dave, thanks for the info I'll try putting it togeather and see what happens
