3020 PTO brake
JD 4020 3020
04-29-2004 11:31:11
Is there a way to adjust the PTO brake? I have a '72 synchro 3020 (side console). The PTO sometimes turns a little when it is off, but it is easily stopped when something is attached to it, or if you try to attach something to it. I am just curious if the brake can be adjusted to grab a little more, or if the brake is almost shot and will need to be replaced. Thnaks for the input.
G-MAN
04-29-2004 16:53:50
 Re: 3020 PTO brake in reply to JD 4020 3020, 04-29-2004 11:31:11
The info Brokenwrench gave you is for a powershift PTO. The synchro-range PTO brake is engaged by a pushrod running back through the clutch housing, which contacts and applies a conical brake shoe to stop the PTO idler gear. You should be able to look up inside the clutch housing and make sure the arm is making good contact with the pushrod with the lever pulled back fully. If it is, and the PTO is still rotating, the pin that keeps the brake shoe from rotating could be sheared off, allowing the shoe to rotate with the idler gear. This is a fairly common occurence when the PTO brake is used to stop a large rotating implement. It might be as simple as adjusting the PTO clutch linkage to allow the fork to fully engage the pushrod/brake, or it could be as complicated as splitting the tractor in order to replace a sheared pin or worn-out brake shoe.
Brokenwrench
04-29-2004 15:42:45
The pto brake is non adjustable. The linkage should be checked to be sure it is actuating the brake circuit. Follow the linkage down from the dash lever to where it attaches to a small lever just above the bellhousing. Make sure the lever is tight on the shaft it attaches to,a little bit of slop there can keep the brake from applying properly,as well as not engaging the clutches fully as both are hydraulically operated.
