3020 injectors
L. Hall
04-29-2004 06:54:44
Can the injectors be adjusted without dealer work?
G-MAN
04-29-2004 07:43:42
 Re: 3020 injectors in reply to L. Hall, 04-29-2004 06:54:44
Which style of nozzle, pencil or Bosch/Scintillas? You'd be lucky to find a dealer that would mess with the pencil nozzles. Yes, they're easy to adjust opening pressure on, if you have a nozzle tester, but they'll run you all of $70.00 per nozzle for brand-new pencil nozzles, so by the time you pull the old ones, clean them up, test them, adjust them and reinstall them, you could have just slapped a new set in and probably be money ahead. You can probably get rebuilt units of the earlier nozzles for about the same money through an injection shop. And, if there is tip linkage or a poor spray pattern, they're going to need more than a pressure adjustment. There are very few shops around that do their own fuel system work. It just about all gets farmed out to certified injection shops. We consign various rebuilt nozzles from one, and send any pumps that need work in to them for repair.
