Controlling down pressure on 3 pt
Dug
04-28-2004 21:01:59
I have a JD 2510, can I controll the down pressure on the 3 pt hitch? Specifically, while blading is there a "floating" and "constant" pressure option?
Thanks in Advance,
Dug
Mike M
04-29-2004 07:47:44
 Re: Controlling down pressure on 3 pt in reply to Dug, 04-28-2004 21:01:59
No down pressure but you should have a lever that may be down by your right foot (it is on a 4020) marked L -L&D - D put it in the depth position D
Bob
04-29-2004 06:52:50
There is no "down pressure" on a 2510. The hitch is hydraulic up, and gravity down. The heavier the blade, the more down pressure there will be on the cutting edge.
Does your three-point position control lever work properly, so the hitch will stay at the height you set it?
