64 3020 and 48 loader match up
Gary in TX
01-26-2004 08:38:12
Hey guys,
Along with the other post on the board on 48 loaders I wanted to also post some questions on this matter. What are the advantages and dissadvantages of mounting a side frame #48 loader on a 3020/3010 tractor? Whats the best way to go about it to ensure that everything stays in working order? I have heard of frame mounting bolts getting loose and wallering holes out and only being able to repair this one time. Whats the remidy for this situation?? anything that can be prevented as far as breakdowns is something to be looked at. Parts are too dang high. We won't open that can of worms right now though, :o). Any other thoughts or advice would be greatly appreciated.
The 3020/48 combinattion will be used primarily for loading round bales, maybe some occasional dirt work, but I have a 4430 with a 725 loader on it that will be my prime loader. The 3020 is just going to be kinda the back up and secondary loader tractor. The one that will be hauled to the hay field to load up trailers. Mainly because its a lighter tractor and more easily hauled on a gooseneck flatbed.
John
01-26-2004 14:49:10
 Re: 64 3020 and 48 loader match up in reply to Gary in TX, 01-26-2004 08:38:12
By your description of a "side frame 48" i`m assuming its the quiktach model. ( no mounting to the rear axle, and wraps around the tractors nose) Well the first advantage is its quick tach so you dont have to dedicate the tractor to it in the off season. I like the qiucktach wrap around the nose frame because it transfers the lift strain directly to the frame of the tractor, not the side frame or engine. I had a 48 (Quicktach) for 20 years on a 1020 and then on a 2440 for a few more. It was a wunderful loader. But I traded to a 620 loader because of the quiktach bucket to fork setup. (Sorta miss the visibility of the 48) I suspect that a quicktach will be fine for moving hay and a bit of dirt werk. Check the mounting bolts occasionally would be my only suggestion. But remember it is a farm loader. Not an industrial stronghorse. Any more questions, dont be bashful.
John
01-26-2004 14:56:18
 Re: Re: 64 3020 and 48 loader match up in reply to John, 01-26-2004 14:49:10
Minor correction... There is still some lift weight transfered to the tractor sideframes with the quicktach style. Thats why there is a factory designed reinforcing plate to back up the engine sideframes. The rear axle unversal mount style mounts from the front of the engine sideframe and the rear axle.
