2 JD 50 questions
Tye
04-28-2004 17:15:18
I noticed my generator wont start charging until about 5-6 minutes into operation. Can anyone tell me what might be the problem? Second question, where on the oil gauge should the needle be when the engine is running? Thanks. Have a great evening.
John Van Valkenburgh
04-30-2004 12:03:09
 Re: 2 JD 50 questions in reply to Tye, 04-28-2004 17:15:18
Tye,
I'll agree with Bob. Sounds like a regulator problem. They are adjustable, but not expensive and I fixed mine by getting a new one.
My 50 oil pressure runs between "M" and "H" even at hot slow idle. Slightly closer to "H" when cold and running at fast idle. There is an oil pressure adjustment on these machines. Its on the right hand side of the engine below the 1st reduction cover (i.e. below the clutch). Its next to the little screw out port where you check the engine oil level. There is a bolt with a lock-nut that is used to adjust the oil pressure relief.
Bear in mind that the engine oil pressure gauge is not gospel. The factory suggests using a calibrated gauge, but the factory gauge is better than none.
Best of luck,
John
1953 Model 50
Bob K
04-29-2004 09:09:14
I'm not an expert on generators, but it sounds like the cut-out relay in your regulator isn't closing until the charge rate gets pretty high. I think there is a spring adjustment inside the regulator to reduce the current needed to kick the generator in. Do a little more research before pulling the cover off the regulator.
The oil pressure needle on my 50 runs between M and H at nearly all throttle settings, but closer to H at higher engine speeds. The only time it falls below M is when the engine is coasting to a stop after shut-down.
