37 B Flooding
Dennis
01-26-2004 08:36:38
Have a '37 B trying to start for the first time after complete overhaul. Get smoke out of the #2 cylinder, but #1 cylinder is flooding. Have installed new mag., wires and plugs. Rebuilt carb. but has sat for 2-3 years dry. Has good compression and good blue spark out of both plugs. Any ideas would be helpful. Thanks in advance.
Clooney
01-26-2004 14:36:12
 Re: 37 B Flooding in reply to Dennis, 01-26-2004 08:36:38
Dennis, you didn't say what mag you are running.. If the original Fairbanks Morse or even Wico AP you could have it timed incorrectly.. Those gear reduction mags MUST be timed to fire on compassion & not exhaust.. Make sure you have a spark at TDC compression on both sides.. You need to see a spark as the L/H impulse writing on the flywheel is directly rearward on compression L/H side & when the L/H impulse writing on the flywheel is directly forward for R/H compression..
~If you are running a wico C or X then all you need is to see a spark at TDC for both sides & it doesn't matter if on compression or exhaust..
~If your spark is in the correct place per above then you might be fighting a sticking valve or rust on a valve face or seat [if that's the case you might have to pull start it the first time]..
~You might want to try running a compression test on it & if low put about 3 oz of oil in each cylinder as the cylinder walls might be dry from that extended sitting [a common problem on long stored tractor].. With one cylinder wetting out & the other dry it could have sticking valves [you might pull the rocker cover & check that]
~It sounds like your carb is working if you are flooding one cylinder & if the carb isn't dripping fuel from the carb or gaskets it probably doesn't have a stuck needle..
~Another thing to check is to check the spark again,, just because it will spark across a plug while out of the engine doesn't mean it will spark a wet spark plug while under compression.. take a [known good] spark plug, then open the plug gap to 3/16" [use a 3/16" drill bit as a gap gage, then install in each plug wire & lay on the block, then turn the flywheel in the starting direction [leave the original plugs in the engine for cranking drag].... You need to see a bluish spark jump that 3/16" gap to have enough spark to start that engine.. If you don't have a good spark that jumps that 3/16" gap you have probably found your starting problem [if your spark is weak, post back or E-Mail & give us the mag type for trouble shooting on the mag].
~If you had the engine apart verify your cam timing is lined up correctly [use the "L/H ex open" on the flywheel to check against the L/H exhaust valve's actual opening..
~With all that fuel on the plugs you might need to install new plugs again as once those plugs fuel foul they tend to bleed the spark down the center electrode & not across the plug gap..
~One more thing,, you might try starting it with the air cleaner to carb pipe removed.. It's possible mice have built a nest in the intake system....
~If you have good compression, a good blue spark AT THE CORRECT TIME, a good fuel air mix with clean fuel then it will start,, what are you missing??
[email protected]
John T (carb)
01-26-2004 09:40:53
Dennis, with the air intake removed, if the gas is turned on, gas dont run out the carb does it???? The oil dont have a bunch of gas in it or gas smell or over filled on level is it??? Sitting a long period can stick the needle valve in location and she dont rise to shut off as it should like Billy was referring to. Last time my 38 B sat a long time the needle stuck and gas ran out the carb and she flooded big time. A good needle n seat cleaning cured it. Turn the gas off at the sediment bowl after shut down if it has one. I run a tad of 2 cycle oil in my gas and use sta bil which helps durign storage, cuz needles can stick and usually in the down open position since thats where they end up if teh carb is drained.
John T
John T
01-26-2004 09:31:41
Dennis, although you say she has good compression, if its sat a long time, I would still try to squirt a lil oil into each cylinders plug hole and turn her over a few times to maybe give her a better ring seal, then install fresh plugs, dont over choke and flood, and try it.
1) Even though you say they are new, if the plugs have been real gas wet too much, you might even try a new set, maybe the side wire electrode types like the Autolite 3077 or equivalent.
2) You say she has a good blue spark, are you sure the wires are on the right terminals?? On the non gear reduction drive mags like the Wico C or X etc., if the wires are reversed she wont run but may pop n bang and kick the flywheel backwards. (A simpe wire reversal would make them run if on wrong) The mag is surely snapping good and sharp each 180 of flywheel rotation (depends on mag) ?? (Or else no good blue spark)
Also if shes sat a long time, just to be safe, I would check the points gap and polish the surfaces with a shop rag etc to remove any gray oxide coating from sitting. Of course, replace if burned or pitted or carbon coated. While inside, check the cap for moisture or cracks.
3) Where are the carb top needles currently set?? Initial rough in is 1 3/4 to 2 out for idle needle and 3/4 to 1 out for load needle, try that.
4) Any chance youre over choking and floodig it??? Many like full choke only about 2 flywheel turn overs then maybe 1/2 to 7/8 choke to avoid flooding. A lot of wet vapor out the stack and over wet plugs is a sign of flooding of course.
5) Is the gas clean, fresh and water free??? Maybe drain the old n replace with fresh and flush out whats in the carb bowl and try it. Is the air cleaners lower bowl free of water???
6) You might check the mags initial base start timing. She should snap n fire right when the Left Hand Impulse timing mark on the flywheel passes by the flat mark on the tractor at 3 o clock. If not, loosen the mags mountign bolts enough to rotate it CCW to advance or CW to retard that startin spark timing.
7) You might check the chokes butterfly plates operation.
She needs clean fresh water free fuel, compression, proper mix of gas n air, and a hot blue spark near TDC to run of course.
If all checks out, if it were mine I would pull start her a bit to build up good oil pressure and see if she fires or backfires or pops or bangs or floods the plugs wet or starts.
SUMMARY
Check or replace the plugs, clean fresh gas, a lil oil in the cylinders, be sure of base start timing per above, be sure plugs on right wires, check carbs needle settigns, dont over choke, maybe pull start, and see what happens.
Post back or e mail [email protected] any questions.
Good Luck n God Bless
John T
Billyiron
01-26-2004 08:56:16
If the carb was never tried ,maybe the float has a leak and filled with gas,,,,,
John T
01-26-2004 09:43:33
 Re: Re: 37 B Flooding in reply to Billyiron, 01-26-2004 08:56:16
Billy, last time my 38 B sat a good while the needle sure stuck in the down open position also, use of 2 cycle oil and sta bil etc in gas seems to help some, and I had to clean mine before she worked right again.
John T
