720 tach hour meter problen
Hank
04-28-2004 15:24:23
The cable going to the tach does not turn when engine is running. Cable is not broken. Any ideas what the problen could be??? Thanks.
F-I-T
04-28-2004 15:58:01
 Re: 720 tach hour meter problen in reply to Hank, 04-28-2004 15:24:23
third party image
Hank:
You didin't say if it was gas or diesel. That could make a bit of a difference.
Anyway...
Could be either the driver or driven gear in the governor case. The one on the governor shaft is nylon. Not sure I remember the material for the driven. If you remove the cabe at the governor end, and it is not turning for sure, you might apply a bit of pressure on the driven shaft/fitting and feel that it's trying to work. If there is room, you might be able to remove the driven unit and verify that it is all right. If not, you'll need to go into the governor and press a new gear on.....and it's quite a bit of work.
Frank
