JD 1020 Hydraulic Leak
mark
04-28-2004 14:32:36
I picked up a 1020 a couple of weeks ago w/ a leak from the load control shaft. It looks like from the JD parts website that the inner bushing doesn't have any seals or o-rings. There is an o-ring and another seal that are on the outside of that bushing, but they're basically useless. I haven't pulled the shaft yet, because I'm new to this and don't want to make the situation any worse. Hydraulics work fine, just have to add a little oil now and then. Any suggestions?
Ernie
05-01-2004 07:23:16
 Re: JD 1020 Hydraulic Leak in reply to mark, 04-28-2004 14:32:36
I've got a JD 1520 that was leaking the same way last year. I took it a part last winter and slide the shaft to one side and replaced the o'ring and seal on each side. Also put new bushings on each side and shimed it. Stopped the leaking completely. About a two hour job, very simple. If you need any more imformation e-mail me.
