4320 Injectors
Scott
01-26-2004 08:33:12
I have owned my JD4320 for 6 month now. Every time I run it my cloths smell like diesel fuel. It always blows out blue/white smoke that makes my eyes tear from the smell of diesel fuel. It start good even in 20 degrees. It has 6,187 hours. I contacted the previous owner and he owned it from 4,000 hours to 6,140 hours and he said he never done anything to the injectors. Do I have an injector problem?
will
01-26-2004 14:21:29
 Re: 4320 Injectors in reply to Scott, 01-26-2004 08:33:12
Scott, Your 4320 should smoke white, and blue when it is 20 degrees outside on its initial start, but not after it warms. Is it ever getting warm? It should run a minimum of 160 degrees. Diesel needs heat and compression to ignite. At 6000 some hours it would definitley be a good idea to have those injectors checked for opening pressure and spray pattern. If this tractor idles around all of the time that could definitley be a problem. It needs to be pulled every once in a while to get the carbon buildup off the injectors tips, as they need to be clean to spray correctly. If your injectors test good I would check valves for adjustment. A few silly questions, but is your turbo spinning, can you hear it whistling? Have you checked the air filter? Diesels need mass amounts of air. Not trying to insult your intelligence at all, but I have no Idea about your background, or how much you know about turbo charged diesels. Please let us know what has happened as you progess
Rob
01-26-2004 10:39:06
My cousin had a 4520 that did the same thing. Smoked like a freight train until it warmed up and started working hard. She would sure pull though.
ET
01-26-2004 09:27:14
It sounds like the pump has been turned up for more power. There is a lot of unburned fuel coming out the exaust when the tractor isn't working and up to tempature.
Bob
01-26-2004 10:35:54
 Re: Re: 4320 Injectors in reply to ET, 01-26-2004 09:27:14
Just because the pump is turned up to allow more fuel at full load does not mean the engine is getting more fuel at idle or light load. If that were true, the engine would simply speed up. That concept seems to escape many people.
If there is unburned fuel in the exhaust at idle or light load, some things to check would be:
1.) Proper engine operating temperature.
2.) Injection pump timing and timing advance.
3.) Injectors, for proper tip for the application, and crack pressure.
4.) Camshaft lift and timing.
5.) Compression.
6.) Intake air restriction.
Obie
03-21-2004 18:27:23
 Re: Re: Re: 4320 Injectors in reply to Bob, 01-26-2004 10:35:54
Does anyone know how to get more power out of a 4320 with the stock pump on it? What would bigger injectors do for me? Basically I can't change the pump for tractor pullin in the farm stock classes, but would like to get more power out of that rotary pump
Russ
01-26-2004 13:31:34
JD 4320 Fumes; With the Turbo ramming air and 116 plus horsepower this could be normal or expected performance/behavior.
Try a high idle after initial start to let internal components see nominal temperatures(perhaps 10 to 15 minutes).
If you detest diesel fumes go for a gas or LPG
beast.
Breathe thru a special filter mask/cartridges
until its clearer off the stack or working hard
enough to clear the smoke jungle.
