JD 60 Howling noise
Tyler
04-28-2004 10:55:46
Wondering if anyone has had this before. This is a JD 60 Gas burner . When the clutch is engaged , with or with out the trans in gear, It has a loud howling noise that sounds like it is coming from around the first reduction gear area. Anyone had this happen and what can I expect to have to do to it.
Thanks, Tyler
Ron
04-28-2004 19:53:30
 Re: JD 60 Howling noise in reply to Tyler, 04-28-2004 10:55:46
You arent talking about the normal Howling the clutchdrum makes on a lot of the 2-Cylinder tractors, are ya..???
Rick in central MD
04-28-2004 11:52:12
Tyler it sounds like it would be bearings in the first reduction gear, there is a outbord bearing infront of the cover with a plate held on with two bolts, take this plate of and you can inpsect this bearing, the other is on the inside on the same shaft, best thing to do is take the transmission shifter asembly off (I think) and try to shake around the top shaft to if the bearing are the problem. This is a common problem on two cylinder JD tractors
