Clutch 3010D
Bob
04-28-2004 06:45:29
I am about out of adjustment ( free play) on my clutch,lately I have had to adjust @ every 100 Hours. Is there something else to be done, I have one (1) asdjustment left. What is the expected cost for putting in a clutch? How do I grease the TO Bearing?
Rodney A. Johnson
04-30-2004 06:31:47
 Re: Clutch 3010D in reply to Bob, 04-28-2004 06:45:29
When I had my 3010D overhauled a couple of years ago, I looked into replacing the clutch (since the tractor was already split). JD wanted 700USD for a new clutch. Compared a new one with my old one and decided I didn't need to replace it.
Labor for splitting a tractor runs around 700-1000USD at most dealerships. If you have a car jack and a slab of concrete, you could split the tractor yourself. Just block the backend up and make sure the wheels cannot move. Then when you have everything disconnected use the car jack to roll the front end back. I recommend getting a hold of a service manual if you decide to go this route. FYI, I believe you can get an after market clutch for around 400-500USD.
To get at the through out bearings, there is a place under the tractor that can be removed for access to check the clutch, etc.
