Battery Charging ??? for Electrical Gurus......
Gord
04-28-2004 06:29:24
Good-day all,
I have a 24 volt winch on my John Deere hauling trailer and two 12 volt batteries hooked in series to run it. The question is, can they be charged from my 12 volt truck system and how can that be done? Some buddies of mine and I were hashing this out and figured it might be possible with some sort of series parralell switch like on the big rigs but we weren't sure how to do it.
Many thanks to all, Gord.
John T
04-28-2004 17:01:51
 Re: Battery Charging ??? for Electrical Gurus..... in reply to Gord, 04-28-2004 06:29:24
Gord, YES it is "possible" to charge the winch batteries (assuming they are 12 volt batteries) either one at a time via an automatic or manual A B switch and enough relays (provided you solve any grounding problems) Orrrrr rrr both at once, provided you can configure a 12/24 volt series/parallel switch similar to what some semis use AND DEPENDING ON IF THE MOTOR IS FRAME ISOLATED. HOWEVER, there are numerous connection and groundign issues that need to be addressed.
1) Is the winch motor totally frame isolated?? If so, it would have 2 power post inputs NEITHER OF WHICH has a connection to its frame/case (it has no grounded brushes or fields or armature). On some winches equipped with a reversible motor, they already have a rather complicated reverser solenoid and separate power input posts but may or may not be isolated.
2) If the winch motor is NOT isolated, its gonna be a lil harder to charge the non grounded battery (via the cheaper simpler way) from the truck until you can solve any groundign problem between the truck and trailer.
3) If its totally isolated and you can rig a 12/24 series/parallel solenoid, thats the easiet way to make her charge via the truck, but may cost more.
I gotta go to a Lions Club meeting but will check back when I return. BUT until I could see the winch wiring schematic,,,,, determine if its a frame isolated motor,,,,, ,, and see if it has a reverser solenoid and figure out any ground problems, Im not gonna post every possible wirinG method and cornfuse you in the meantime. The simpler cheaper ways might involve only the use of relays, switches, circuit breakers n wire, while the more expensive ways would require the addition of a series/parallell switch etc.
I will check later, see if the motor has a reverser and if its totally issolated (brushes, fields, armature etc) from frame and we will proceed from there.
Good luck n God Bless
John T
Gord
04-28-2004 17:35:55
 Re: Re: Battery Charging ??? for Electrical Gurus. in reply to John T, 04-28-2004 17:01:51
Hello John T., I'm going out after supper, I hope, to see if it is frame grounded as you and Clooney talk about so hopefully I'll get back to you guys this evening (my time anyway) And thanks so much for your input, Gord.
Clooney
04-28-2004 11:58:01
Gord, sure they can.. The problem is how complicated you want to make it in doing so..
~Because those batteries are in series with a chassis ground on one end of the series [I doubt that winch has an isolated armature & fields] you won�t be able to easily charge them with 12 [actually 13.7-14.2] volts while still is series..
~The difficult way is to install a solenoid or high amp switch in the connector cable between the batteries then open that switch when the winch isn�t being used.. That will also require the trailer be unplugged from the truck [or a relay, or diodes, or switch added] so the 24 volts doesn�t backfeed the truck when the batteries are re-connected together..
~If your truck has a heavy gage battery feed wire in it�s trailer harness [a lot of factory set-ups do] then you could just wire that to each battery using an ignition switch controlled relay or diode[s] so it only feeds power to the winch batteries when the truck is running.. It would also protect against the trailer batteries trying to supply starting power while cranking the truck [that MUST be protected against]� This set-up would only work if the batteries were not connected in series at the time of charging & the non grounded battery�s negative post grounded to the same ground as the charging source.. [difficult to accomplish]..
~ As you can see it won�t be easy to rig an easy to use, passive system that doesn�t require some input on your part to flip switches & set the system in motion..
~I would think the easy way would be to use a solenoid in the connector wire between the winch batteries that ONLY energizes & hooks the batteries together when the winch control is triggered, then hook a FUSED wire from the trailer tail light circuit through a separate diode to a single wire with an alligator clip at the winch battery area.. Then all you would have to do is clip that alligator clip on the positive post of the already grounded battery & it would charge while driving with the trailer lights on . Then it could be moved to the other battery at fuel or rest stops to charge the other battery [that second battery would also need a small clip on ground wire added for charging but removed before the winch was energized].. Again a real pain to remember to do the correct things.. A relay could be added to help but that would need some ignition switch control & the truck turned off or the trailer disconnected to use the winch.. Again not a good or easy solution..
~Now what you want to hear.. There are some 10-18 volt input,, 26-28 volt output converters that are used in the boating world & industrial trucking community that will allow you keep the 24 volt winch battery pack intact with no modifications & charge it as a 24 volt system from the trucks 12 volt supply. That would need that battery power wire in you trailer harness to supply the power & possibly an ignition controlled relay up front in the truck to de-power that converter when the trucks ignition switch is turned off.. That would also allow the truck to remain running & supply power to the winch batteries while the winch is being used.. [you will need to call some of the 12/27 volt converter companies to see get the specifics of their products].. Remember there are a bunch of 12/24 volt converters out there but a 24 volt converter won�t charge a 24 volt series battery pack.. It must have at least a 26 volt output & preferably a 27-28 volt output to charge those winch batteries..
~I checked my engineering supply data base & found one such converter [click on link below]..
Any additional questions just post back or E�Mail as there are many complicated ways to go but nothing easily added to charge those 24 volt in series batteries..
[email protected]
Gord
04-28-2004 13:03:07
 Re: Re: Battery Charging ??? for Electrical Gurus. in reply to Clooney, 04-28-2004 11:58:01
Thanks so much Clooney, I am pretty sure the winch is not grounded to the frame as it is like a receiver hitch the way it mounts and it has a cover over the recepticle where you plug in the main power both pos. and neg. in a plug that is wired direct from the batteries. However I will have to verify that with a meter.
Gord
