3010 with a 48 loader...help
Stuart
01-26-2004 08:03:30
I have a friend who has a 3010 gas with model 48 John Deere loader on it. I have heard of stiffener plates that go on the under side of the loader from side to side. These plates I have been told help to keep the frame rails from cracking. The person I heard this from has a 3020 and loader but I am not sure which loader. Are these plates applicable in my situation or am I safe to use it as is. Thanks for all the help
Stuart
01-27-2004 07:43:58
 Re: 3010 with a 48 loader...help in reply to Stuart, 01-26-2004 08:03:30
The loader is a quiktach loader. Do you really need the stiffener plates to lift heavy items? Does the loader have to be off to put them on? I appreciate all of the help on this subject
John
01-27-2004 11:29:05
 Re: Re: 3010 with a 48 loader...help in reply to Stuart, 01-27-2004 07:43:58
The reinforcement is sandwiched between the engine side frames and loader mounting brackets. I cant tell if the loader does or doesnt have to be in the tractor to install the plates. Aparently Deere thought they should be there. Not that that means it wont work without them. Personaly I believe they spread loaders lifting and pushing stress over a wider area. And that should help keeping the bolts from wallering out. The reinforcement plate looks like its 1/2" thick and four inches wide and probably 20 inches or so long.
dale
01-26-2004 19:22:37
I had exactly the same thing that you have. The stiffener plates go along on the inside of the tractor frame instead of across the tractor and are of different lengths(2 per side). Best I remember I made them from just plain flat iron. Had to knotch out for something behind the tractor frame and drill alignment holes, but it worked. After all was said & done, I sold the loader but kept the tractor. Really wasn`t worth the time I spent. Wouldn`t lift that much.
John
01-26-2004 12:27:32
I am looking at my parts and operators manual for the 48 loader. It shows 2 types of mounting brackets listed for the 3010. A quick tach loader frame which bolts to the sideframe along the engine, and a universal frame which mounts to the rear axle and forward to the engine side plates. All the universal frames have a crosstube just below the loader mast. It appears to be about a 4 inch round tube which holds the two universal frames (LH and RH) and is bolted inside a receiving tube which is welded to each (left and right) side of the universal frame. The Quicktach uses two reinforcing plates on either side of the engine side plates. Paralell with the engine. By using two diferent sets of mounting frames and brackets, the universal frame can be mounted on JD A B G 60 70 520 530 620 630 720 and 730 tractors and 2510 2520 3010 3020 4000 and 4020`s. Not to mention a buch of IHC farmalls from H`s up to 856`s. So I guess it boils down to whether you are putting the Quick-tach frame or universal framed loader on your 3010. Dont be bashful. Post back If I can help. John
PS. If the loader frame wraps around the nose of the 3010 with a 4-5" tube its a quicktach.
Pat
01-26-2004 11:52:15
The manual (still available from Deere) shows stiffener rails used on several installations. They bolt on the inside of the frame, in conjunction with the outer brackets. I used the manual pictures as a guide, and made some for my 1020 for a 48 loader. Used cardboard and trial and error for a pattern for size and bolt locations, then cut and welded 1/2 inch steel plate. Hope this helps. Pat
Gary in TX
01-26-2004 08:28:06
Hey Stuart,
I have a 48 loader that I will be putting on a 64 model 3020 here pretty soon. This would be some good information for both of us. Of course anything going under the side rails will have to be cut out for the oii pan. Don't know just how strong that would be then??? I have heard of making frames that go all the way back to the axle for extra strength. Hopefully we can both find out some info here.
