I recently purchased a JD 3010 Diesel at a sale, and am hoping to do some custom baling with it. At the same sale I also bought a 2350 Gehl Discbine. I'm ashamed to say that I neglected to check the PTO on the discbine to be certain it was a 540 RPM before I bought it. Needless to say, it is a 1000 RPM. After reading old posts here, I'm under the impression that all one must do to convert a 3010 to 1000 RPM is take off 5 bolts to switch splines. Could it possibly be that easy? I also wanted to inquire about another item on this 3010 from this astute group. The transmission will not go into the high gear (I think it's the 6/8) slot. It seems the shifter won't go down far enough (on the left side of the shifting mechanism) to fit into the high gear slot. Is it a misadjustment, or are those two gears toast? Next, it has a really nice high-backed seat on it that I've seen on the Net. However, mine is in very poor shape and the arm rests (which swivel up) are broken. Was this the original seat, or is it supposed to be the steel 3-part low-back seat that was original. I'm just curious--this will be a working tractor, not a show piece. Still, no harm in it looking like it should. Thanks for your assistance! It's the PTO question that's really important to me. P.S. By the way, it has 13.9 x 36 tires on it--are those the original size?
