145 Loader glitches
Tony
04-27-2004 10:41:43
Do all JD145 loaders have a "float" position for the boom valve? Mine doesn't seem to be present or doesn't activate.
The dump cycle of the bucket often stops about half way through cycle. If I re-activate the control to dump, the front wheels "snap" a bit as if hydraulic pressure surges.If I "scoop" bucket up a bit and then dump, the cycle goes through the full cycle. I have checked the hydraulic fluid and find some bubbles/foam after moderate use. Any ideas where to begin?
Anderson
06-26-2004 16:42:52
 Re: 145 Loader glitches in reply to Tony, 04-27-2004 10:41:43
I have a 145 loader on a 74 830 and my valvehas a float position for the boom. It is possiable that a previous owner has replaced the valve with a valve that doesn't have a float position. check the underside of the valve, the boom side should be an inch or two longer than the bucket side. On the problem with dumping the bucket, my bucket will pause for several seconds about half way through the cycle when the bucket is empty or lightly loaded. this may be causet by the bucket moving faster than the tractor's hyd pump can move fluid, when the pomp fills the space in the cylinders the bucket will go on through the cycle. I hope this helps.
