Edison mag on a styled A ?
Brad
04-26-2004 19:54:07
I have an early styled "A" with an Edison CD mag. All the JD guys tell me this is incorrect. I do have some old pictures of the tractor when it was at least fairly new (its a one-family tractor) but my Grandpa, who bought the tractor, passed away 20 yrs ago, so asking anyone who was there is out of the question. Were there any styled "A"'s with this mag, or was it possibly switched many years ago? Also, any tips on finding parts for Edison mags? Thanks alot for any help.
Duane Larson
04-27-2004 06:27:34
 Re: Edison mag on a styled A ? in reply to Brad, 04-26-2004 19:54:07
Brad,
The Edison Splitdorf CD spec 0010 was used as original equipment on A's in the s/n ranges 462101-462499, 464501-465099, and 466400-478499.
What parts do you need for the magneto?
Brad
04-27-2004 18:59:25
 Re: Re: Edison mag on a styled A ? in reply to Duane Larson, 04-27-2004 06:27:34
Thanks alot, guys...our "A" would fit there; its SN 477682. As far as parts, I'm really not sure yet, I was tinkering with it a while back and I'm getting no spark. Surely, anyway, I'll need a gasket set. Not sure about a condensor or points or anything else...I don't know much about mags
Duane Larson
04-27-2004 21:19:34
 Re: Re: Re: Edison mag on a styled A ? in reply to Brad, 04-27-2004 18:59:25
Brad,
Glad to help. The ES were good magnetos, well worth saving in my book. Make sure the impulse is functioning as you rotate the magneto drive cup - you should feel a spring resistance and hear a snapping sound as it releases. If not, your impulse spring is probably broken and needs replacement.
Pull the front cover and make sure the point surfaces are shiny - use some emory cloth to polish them up. The high voltage prong of the coil sticks out, and using an ohmmeter, connect one lead to the ball on the end of the prong and the other lead to the case. The coil should read somewhere about 8000-9000 ohms (detailed numbers are in the shop). If the coil provides no reading (ohmmeter needle doesn't move) it is open and needs to be replaced. The condenser probably should be replaced, I have found one that works great but again the info is in the shop. Make sure you properly time the gears when reassembling - it is fairly obvious which marked teeth go together.
Mark's Magneto makes really nice gaskets for the ES - that's where I get mine. His phone number is 860-887-1094.
Clooney
04-27-2004 03:38:56
Brad, if you have a real early styled "A" it could have possibly had the E/S CD mag on it.. I don't have my good true books handy where I'm at the moment but I believe that CD mag was used on the styled "A" through S/N 478500..
[email protected]
