HOW TO REMOVE PRE-CLEANER FROM JD 530
MIKE LOKAI
04-26-2004 19:52:05
I HAVE A JOHN DEERE 530, FOR COSMETIC REASONS ,WOULD LIKE TO REMOVE THE PRE CLEANER.
IT APPEARS THAT THE INTERNAL PLUMBING IS INTACT.
HOWEVER THE OPENING TO THE AIR CLEANER MAIN TUBE
IS COVERED BY A THIN SLEEVE. CAN THIS BE REMOVED AND WHAT ABOUT THE BLOCK SHIN ON TOP OF THE AIR BREATHER???
Tyler
04-27-2004 07:18:51
 Re: HOW TO REMOVE PRE-CLEANER FROM JD 530 in reply to MIKE LOKAI, 04-26-2004 19:52:05
Mike I'd be interested in purchasing the precleaner if you are willing to part with it. Please give me an email at [email protected]
Thanks
Tyler
Jim B
04-27-2004 04:16:12
Mike,if you want to sell the precleaner email me [email protected] Thanks,Jim B
Clooney
04-27-2004 04:10:08
Mike, that tube should pull out.. If not you will have to crush it's sides in then pull it out..
~As for that spacer block [it was only used on the 530 with air stack]..
~Just remove the spacer block, remove the inner tube, then bolt on a cover & gasket to close the top off.. The cover is P/N-- B3557R & the gasket is B 3558R.. You can easily make both the cover & gasket..
[email protected]
