JD 1020 hydraulic question
Sam
04-26-2004 18:17:08
Hello, I have a 72 JD 1020 with independent PTO, and 48 loader. The loader and power steering work fine when I am not using the independent PTO. When the PTO is on the 3PNT and the power steering do not work very well at all. PTO on - The 3PNT barely goes up, and the steering tightens up. Any ideas? All help is appreciated. thanks, Sam
Brokenwrench
04-27-2004 03:38:02
 Re: JD 1020 hydraulic question in reply to Sam, 04-26-2004 18:17:08
You have a bad sealing ring in the valve,loose or cracked oil line,or bad seals for the independent pto. This is bleeding off charge oil which is causing the diminished functions in the other circuits when the pto is engaged.
sam
04-29-2004 20:21:37
 Re: Re: JD 1020 hydraulic question in reply to Brokenwrench, 04-27-2004 03:38:02
Hello Brokenwrench, I tried new filter,cleaned the screen and changed the oil --- The rockshaft is still not working while the PTO is on. 'bad sealing ring in the valve' -- do you mean the 'PTO clutch valve actuator'? Cracked oil line? -- how do I check these, How do I fix them? Where would the bad seals be for the PTO? As you can tell I am not very good at this stuff.. Thanks for all help, Sam
s
04-26-2004 19:27:26
Have the hydraulic filter and tranny screen been changed and cleaned lately? The screen is easy to overlook.
