How do I get myself out of this one ????????
louie
04-26-2004 16:14:56
My 68 4020D came with 24V system as you all know. When I bought the tractor the gen wasn`t working among other things.Only the starter worked ,to start the tractor.I put in a 12v conversion made by deere and have been plagued with problems eversince.I`m on my 4th alternator and don`t want to fry this one.I have double and triple checked the hook-up and cannot find anything wrong with it.My quess is there is a short in the wiring harness. Now for the big question. Is there a simple (low cost) way to rewire the alternator and starter to the key switch and battery and elimnate the wiring harness? (The lights,oilpressure& fuel guage have never worked.) Oh! It`s a delco 3 wire alternator and delco JD starter.Thank You
Bob
04-26-2004 16:59:11
 Re: How do I get myself out of this one ???????? in reply to louie, 04-26-2004 16:14:56
It's pretty darn hard to fry a 3-wire Delco alternator with bad wiring. Do you have the #2 terminal on the alternator jumpered to the output stud on the alternator, as it should be?
About the only thing I can think of that would hurt the alternator is a poor connection (intermittant open) in the wiring between the output stud on the alternator and the battery terminal stud on the starter solenoid. To eliminate this poosibility, run a new 10-gauge wire from the alternator output stud to the big stud on the starter solenoid.
