Haybines
Brent
04-26-2004 13:04:34
Does anyone have any experience with a JD 1209 Haybine? What are they like to use? Thanks in advance.
T213R
04-27-2004 18:26:49
 Re: Haybines in reply to Brent, 04-26-2004 13:04:34
I use a late model 1209. The "early" ones had two, single acting lift cylinders to raise and lower the machine, later ones used only one. My machine has the "non-clog" gaurds and uses hydrualic cylinder to swing the drawbar. It does not clog, cuts very well and I'd find it difficult to see how a NH 488 would be any better. I use it about like the other posters---~25 acres per year, and it gives very good service! I'd suggest a 1219 however, mostly because it will be a little newer.
David in MD
04-27-2004 13:31:56
I have a well worn JD 1209 that I too use for about 25 acres of alfalfa/orchard grass. It works well and is a simple machine to work on. I replaced the bushings and bearings in the reel for about a $100. Mine has stub guards and the only problem I've had is if I'm not careful to adjust the hold down clips properly it will break the knife head. I'd recommend the 1219 if possible as it has a 5 bat real, additional indentations on the rolls for better conditioning and perhaps hydraulic swing on the tongue. It may not be quite as good as the NH 489 but it is easier and cheaper to work on.
Buck
04-27-2004 07:02:56
I used a J.D, 1209 haybine for over twenty years.
They work good. The problem with mine is the front reel and tract is worn out.
To expensive to repair, buying new parts.
If you need parts I have them. gear box etc.
Or if you know where I could find a used reel
and tract let me know.
Thanks,
Buck
Dave in S MN
04-26-2004 18:11:07
We use a 1209 on about 25 acres of alfalfa each year. It has worked good for us for a long time. We have done some major work done on the gear box some years back but has worked excellent since then. The only thing that's of concern on ours now is the conditioner rollers are starting to get wore out. Hope this helps.
-Dave R
