A3404R rear weights
stu
04-26-2004 08:11:02
A set of A3404R rear wheel weights. The guy said they came from off a 730. Will these weights go onto the wheels of a 70 or a 720 as well?
Does anyone have any photos of how these are installed? I would really appreciate it.
720Deere
04-26-2004 08:21:17
 Re: A3404R rear weights in reply to stu, 04-26-2004 08:11:02
The A3404R will fit anything from a 50 to a 4020 and maybe even beyond that. The best way to mount them depends on how often you intend to remove or change them. John Deere has a special bolt that is driven into the weight and it makes it easier to install the next weight. The down side is that they cost around $4 each.
Each weight takes 3/ea 5/8" x 3" square head bolts and bolts must be installed in each weight before it is hung on the wheel allowing you to hang the next weight onto those bolts. I have some pictures at home of the bolts and the installation. Send me your email address and I will try to send them to you.
