48 A overheating
RK in Iowa
04-26-2004 08:09:38
My son and I recently purchased a '48 A. It ran fine, but needed fluids changed. We dropped the oil and the anti-freeze. We put new fluids in, but now she runs hot after 15 minutes. The old anti-freeze looked clean, and the outside of the radiator looks okay. Any suggestions? Thanks!
PeteNY
04-26-2004 19:22:20
 Re: 48 A overheating in reply to RK in Iowa, 04-26-2004 08:09:38
RK, we replaced the radiator core in our '48, even though we got one of the better ones with the bigger tubes, it still wasn't circulating, the guy that sold us the core (has forgotten more about JD than most will ever know) told us to get brand name anti freeze (we had TSC bargain stuff)...I didn't believe it but tried out of desperation simply because I didn't want to do it again (those radiators were not one of JD's "better ideas, when it's time to change radiators I volunteer to change the red ones!) and it worked!
Bob
04-26-2004 11:49:58
How are you defining "overheating"? does it boil the coolant, show "HOT" on the gauge, or simply slobber water out the overflow because the radiator was overfilled, not leaving room for thermal expansion?
RK in Iowa
04-26-2004 12:24:08
 Re: Re: 48 A overheating in reply to Bob, 04-26-2004 11:49:58
Hi Bob, Gauge is pegged on HOT, very little out of overflow, lower water line is cool. When setting for a few days, water level is down. Should it be right up to the cap? Thanks!
Robert
04-26-2004 13:49:20
 Re: Re: Re: 48 A overheating in reply to RK in Iowa, 04-26-2004 12:24:08
I have a '45 A, and, assuming your radiator is like mine (cast iron upper tank) I've found that the correct level is just to the bottom of the cast iron upper tank (where you can just see coolant) any higher, and it will come gushing out of the overflow tube as soon as she warms up.
As for level dropping after a few days, I'd look to see if your getting coolant in the cylinders (head gasket or cracked head?). It may be something as simple as a "lying guage", and you could take a cooking type thermometer, and stick it in the coolant to see what the temperature actually is (put the thermometer in when everything is cold, and let her run to see how hot "hot" actually is)---anything short of boiling is acceptable in these old girls. In my case, I went the cheap route on the gauges and have an automotive type that shows about 185-190 when working, but, I don't know that this guage is all that accurate either.
Hope this helps some.
mike in new mexico
04-26-2004 08:27:47
RK- When you change the anti-freeze in the old 'A' -you have to pre-mix the water and the anti-freeze before you put it in the radiator. your tractor doesn't have a water pump and if you put in the anti-freeze first and then add water-the tractor will over heat. you must pre-mix first. hope this helps-mike
RK in Iowa
04-26-2004 09:45:13
 Re: Re: 48 A overheating in reply to mike in new mexico, 04-26-2004 08:27:47
Thanks, Mike. I did use a 50/50 mix.
