318 hydrostatic transmission not working.
Glenn Hyatt
04-26-2004 08:08:45
I have a 318 model with the Onan engine and two electric PTOs. The rear PTO runs a large yard vacuum. On the last use, while engaged, the rear support bracket from the rear electric clutch to the frame broke and allowed the clutch assembly to turn about a � turn where it stopped on the tractor frame. Now I have no forward or reverse. There are no visible leaks and the transmission shows fluid in the rear sight glass. Could this have caused something to fail in the charge pump or transmission? Please help.
Bob
04-26-2004 11:20:48
 Re: 318 hydrostatic transmission not working. in reply to Glenn Hyatt, 04-26-2004 08:08:45
Make sure the input shaft to the hydro is turning, as well as the output shaft to the PTO clutch.
Do hydraulic functions work? The hydrostatic transmission charge pump also supplies the flow for the other hydraulic functions. The charge pump is located in the cast housing around the input shaft to the hydro, held on with 2 capscrews. It is not uncommon for the pin through the input shaft that drives the geroter pump gear to break (shear). Often, there is wear or damage, and the pump gears need to be replaced also.
If the hydraulic lift works, for some reason the free-wheel valves that release hydrostatic pressure, and allow you to push or pull the tractor SHORT distances may be depressed.
WTW
04-26-2004 08:47:00
Glenn, If your hydraulic lift and steering have also failed most likely cause is the roll pin that connects the drive shaft to the hydro unit has sheared. You will have to pull the fender deck to see this connection at the front of the hydro unit. If your hydraulics still work this is not your problem as the charge / hydraulic pump is the first thing driven in the hydro behind this drive point connection. If the hydraulics are working look at the shaft at the rear of hydro that drives your rear PTO clutch if it is not turning when the front is you have broken the drive shaft inside the hydro unit. If this is the case hydro will have to be removed and disassembled for repair. Good Luck Dave W.
Glenn Hyatt
05-13-2004 07:58:42
 Re: Re: 318 hydrostatic transmission not working. in reply to WTW, 04-26-2004 08:47:00
I had missed that pin when I looked at the hydraulic transmission break down in my service manual. Regardless, I took the unit apart and found the pin had not broken. I took the charge rotors to my local dealer for advice, however they do not have much experience with the 318 tractor, and said they looked ok(not much help but very nice people). I did replace the pin with a new one and reassembled the unit. At the same time, I drained and replaced the transmission fluid and filter. The tech at my dealer said he used to turn the back wheels after a fluid and filter change to circulate the fluid in the unit with the tractor on jacks to get the transmission working again and I have tried this procedure with no success.
I have removed and cleaned the "release valves" on top of the unit in front of the charge pump. The manual describes a "bleeding procedure" for the unit, however the procedure assumes the tractor will move. I have no hydraulics at all, and it doesn't sound like any fluid is circulating in the unit. Any suggestions please?
Chris H
07-26-2005 21:40:43
 Re: Re: Re: 318 hydrostatic transmission not worki in reply to Glenn Hyatt, 05-13-2004 07:58:42
Hello Glen,
I know it"s been awhile since you posted this but I just read it and don"t know if the problem was resolved. One thought comes to mind. Have you checked the linkages both external and internal?
Regards,
Chris
