720 LP reliability the 3pt wont go down
Clark
04-25-2004 20:57:40
I am considering buying a 720 LP for haying & genral farm work. Are they reliable and ecomnmical to run? Also the 3 pt presently wont go down.
CLW
04-26-2004 16:25:42
 Re: 720 LP reliability the 3pt wont go down in reply to Clark, 04-25-2004 20:57:40
Clark, I can help you a little. The 720 is a good tractor. It being used you would just need to check it out like any other tractor to see if you can find anything wrong with it. The LPG if in good shape is no problem. In fact it has some advantages over gas and also some drawbacks. The 3-point may need weight on it to go down. If it has the arms on it that should be enough weight but not always. If there are no arms you would need to rotate down on the rockshaft with a large wrench to get it to move.
CLW
Bennett
04-26-2004 18:09:39
 Re: Re: 720 LP reliability the 3pt wont go down in reply to CLW, 04-26-2004 16:25:42
On My JD820 (3 cyl) There's a small bolt thats under the seat on top of the rockshaft housing - needs to remain loose - because if it tightens up, the implement won't go down.
Not sure if it applies to your model but the symptom just jumped put at me.
Hope it helps.
-Bennett
