Deere John 2004
04-26-2004 08:18:27
Re: Clutch Driven Gear on JD 70 in reply to Stretch, 04-25-2004 18:50:07
I suspect, that the difference isn't in the transmission gears, but in the engine rpms. The gas 70 engine is rated at 975 rpms the 70 Diesel engine is rated at 1,125 rpms. According to the Nebraska tests, #493 and #528, the geared ground speeds are identical. It is likely, that Deere, for production economy, used the same transmission gears in both and changed the ration of the clutch drive and the first reduction gear to make the ground speeds the same. That being the case, using 'diesel' gears in a 'gas' would slow all the ground speeds by a ratio .867 : 1; or 1st = 2.2 from 2.5, 2nd = 3.0 from 3.5, 3rd = 3.9 from 4.5, 4th = 5.6 from 6.5, 5th = 7.6 from 8.75, and 6th = 10.8 from 12.5. Of course, this ratio is theoretical, the only way to figure the actual ground speeds would be to count the teeth on each gear set and figure the ratios from that.
