52 JD A oil change
Don
04-25-2004 14:17:37
I just bought a 52 A do not have a owners manual yet Is the oil added right above the clutch and level checked at plug forward of clutch and what weight of oil is best?
Don
Gomer
04-26-2004 22:05:10
 Re: 52 JD A oil change in reply to Don , 04-25-2004 14:17:37
You have it figured out. Where to fill it, where to check it. Have 12 quarts on hand and you will need all of it if you change the filter. I own a '52 "A" and have changed it several times.
dw
04-26-2004 14:56:57
Eleven quarts is right for the crankcase oil capacity.
JDBert
04-26-2004 09:23:06
The level check is on the flywheel side.
Ron
04-25-2004 18:50:01
I think it takes 8 Qts.
Have a new filter handy, and change it to..!!
RH
04-25-2004 18:26:34
The oil is put in and checked at your described locations. I use Rotella 15-40 in my 1951 A. I cant remember the capacity of the crank case because I dont have the manual on hand(its in the shop) You can open the check plug and when it starts coming out as you add the oil its full. I would have at least 3 gallons on hand because going from memory it holds 11 quarts.
