Brass tower in carb, won't come out
ben So Tex
04-25-2004 08:27:39
The brass tower or what ever it is called in my model A carb I cannot get it out. How can I get it out with out messing it up?.... I messed one up before but had an extra spare parts carb handy. I don't have a extra carb for this tractor, Thanks Ben
Gomer
04-26-2004 22:09:00
 Re: Brass tower in carb, won't come out in reply to ben So Tex, 04-25-2004 08:27:39
37 D is correct. One of the most knowlegable persons ever on this board explained it to me that way. Thread the bottom of the nozzle. Install all-thread, washers, nut, pull it out.
JC
04-25-2004 18:16:50
1. I soaked it all in lots of penetrating oil.
2. I used a piece of all-thread that just fit inside the brass nozzle {#10-24 I think}.
I placed a soft brass washer and nut on the end of the thread inside the carb throat and I placed a large washer and a nut on the other end, and very gently tightened the nut and out came the brass nozzle.
I was fortunate that the top of the nozzle did not crush or crack.
Most recommendations on this board involve threading the brass nozzle. I wasn't sure that the threaded brass was strong enough to take the pull!
Regards,
JC
Mark
04-25-2004 10:06:00
Heat the stem of the carb red hot with a torch and allow to cool. It will come right out. have done many this way without any problems.
37D
04-25-2004 09:34:43
I think this has been covered several times before, but the simplest way I have found is to tap threads in the bottom,with an appropriatly sized tap, screw a piece of redi-bolt in,put one or more washers over the bolt,turn a nut down on the bolt, & simply pull it out with the nut. This has always worked for me. The last thing you want to do is pry on the top of the nozzle. That will almost certainly ruin it. When out,clean ALL the little holes in it with a proper sized drill, or cutting torch nozzle cleaner-be carefull not to enlarge the holes!
