720D upper coolant pipe replacement
Denny
04-25-2004 07:29:59
On my 720D the upper pipe, between the block and radiator has rusted out. I got the pipe from Deere and they included two rubber o-rings to go onto the pipe. I was hoping to get some help on replacing this from you guys. Thanks for any and all help. Denny
Clooney
04-26-2004 03:52:53
 Re: 720D upper coolant pipe replacement in reply to Denny, 04-25-2004 07:29:59
Denny, those can be a pain if you just try to poke that pipe in there.. About all you will accomplish is ruining the �O� rings..
~I have done those many ways & so far the best & easiest way is to just grind a slight taper on the end of the pipe so it slides through the �O� rings easier.. Then a I use some tire mounting lube on the �O� rings, place them in the grooves, then use a large socket to run around the �O� rings to fully seat them in the grooves, then push the pipe in using a rotating motion [it will usually go right in]...
~The other way I used to do them was using Franks method, that will also work good but I found it easier to just grind the pipe a little..
~One secret is to MAKE SURE the �O� ring slots are COMPLETELY clean & rust free inside as that allows the �O� rings to fully seat & not stick up out of the slot so far..
[email protected]
Mike M
04-25-2004 16:28:18
To remove the old pipe if it won't pull out heat it up with a torch to burn out the old o-ring. To put the tube in I coat the o-rings with RTV gasket maker then put in casting and smear a little more in. The tubes usually pop in plus on an old tube the RTV helps seal up the rust pits.
F-I-T
04-25-2004 09:17:28
Denny:
Of all the jobs I perfromed during a major rebuild of my 70D, one of the toughest was upper and lower water pipe installation. For that I tried many things, but what worked best for me was to cut three or four strips of shim from an old paint can, and then file the burrs off so they were smooth. Then I oriented them lengthways into the bore, so that they would hold the o-ring in place while I pushed the greased up pipe into place. Then I pulled the shims out and it was done. It took less time to talk about it than to do it ! You might want to have an extra o-ring or two on hand to save a trip back to town in case you cut one.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
Ty
04-25-2004 08:45:04
I always put some grease on the pipe for some lube. Careful not to cut the new o-ring. It happens. Patience and a little elbow grease to get that pipe in the new o ring.
Bob
04-25-2004 09:33:41
 Re: Re: 720D upper coolant pipe replacement in reply to Ty, 04-25-2004 08:45:04
Ordinary liquid dishwashing soap is about the slipperyest thing to use on "O" rings.
buickanddeere
04-25-2004 13:05:08
 Re: Re: Re: 720D upper coolant pipe replacement in reply to Bob, 04-25-2004 09:33:41
Dish soap or official "o" ring grease. Petroleum grease will dissolve your new "o" rings away.
