730 flywheel and other stuff
billyiron
04-25-2004 07:20:35
I tore down the 730 to replace the inner thrust washer, clooneys right lots of work,also found lots of other stuff needed attention; the big question is flywheel, I see in archives mention of taperlocks seems to be a more reasonable place to buy in Tn, Has anyone had experience with tapers, my flywheel had small strips of tin in splines and was soaked in loctite but still loose; I found remains of thrust washer in crankcase, governor weights fell off too and layed on crank housing,,I think thats all; any input will be apprecated;;;;billy
billyiron
04-26-2004 06:12:08
 Re: 730 flywheel and other stuff in reply to billyiron, 04-25-2004 07:20:35
Thanks for all the replys; a guy brought a 70 in yesterday,and when I pulled the flywheel cover I see it had a taper so at least I see what there like,, I think the crank splines on 730 are good, so I guess I go from there;;billy
Clooney
04-26-2004 03:41:41
Billyiron, those Taper-lock flywheels do work pretty good but a lot depends on how bad the crank splines are worn.. If the crankshaft is worn excessively or worn tapered then nothing will stay on, or tight, easily..
~To get those taper-lock�s to stay put they must be re-tightened a few times after use & pounded on with a big hammer while seating the taper lock..
~I haven�t ever had any problems with them but I also replace the crankshaft if it�s worn more than a little, or worn tapered...
[email protected]
dwm
04-25-2004 11:26:40
Have used the taper lock flywheel from eastern Tennessee on two tractors, a 70 G (put on in early 80s), and an 'A' recently with good luck. On the 70, someone had tried to weld the flywheel to the crank with predictable results-it cracked. The 'A' was just loose, with the splines on both the crank and flywheel worn. Some may argue this is not 'factory', but if the rest of the engine does not need to come apart, why not? Depends on what you want. The place in TN does the modification at their shop. In both cases, I took the flywheel to them and had it modified. We've have good results by following their directions. Good luck.
Larry806
04-25-2004 11:13:25
I've heard of guy's having good luck with them. I know of 3 that came from Denglers that are JUNK. A friend bought one for his 730 brought it home & installed it by the instructions Ran it a few min & tightened several times. Every time he ran it . It tried to come off. The flywheel he took off was cracked but the spines looked good. He brought me the tractor I called Tricky Nicky He told me it was my friends fault if he installed it by the instructions He said that's NOT the way to do it. Nick said to drill & tap the end of the crank & put a big washer & bolt in to hold the flywheel on that's what most people have to do. I know of a 720 & 70 the same way. My friend had a nos crank & flywheel put in his 730
