3010 injec. pump
Ben
04-25-2004 05:18:47
Started my 3010 diesel and it ran up to 1500 rpm. No throttle response below that. It has over 800 hrs on it. Am I looking at a rebuild pump or is there something stuck in the fuel system? Thanks you guys are always very helpfull.
jdemaris
04-25-2004 14:57:16
 Re: 3010 injec. pump in reply to Ben, 04-25-2004 05:18:47
Was that a typo when you posted 800 hours? Even 8000 hours is not an awful lot for the machine or pump. I've got a Deere here with well over 30,000 hours on it with the original injection pump. I've rebuilt the engine twice, but never the pump. 3010 pump has several internal pump parts that tend to fail if it hasn't been updated. First, check for air in your system. Air in the fuel will make the throttle unresponsive. Also, which pump does your tractor have? If it's a Roosamaster CB, there is a set of rack and pinon gears that operate the throttle and tend to go bad. They can be replaced without removing the pump. If you have the totally different Roosamaster DB pump, look for the little rectangular steel side plate on it that's held on by two screws and hides the timing marks. Take it off and see if it's clean inside. If you see what looks like little mouse turds, then the plastic governor weight retainer dampening ring is broken. By the way, the CB pump is round, the DB is more rectangular.
Ben
04-25-2004 15:37:07
 Re: Re: 3010 injec. pump in reply to jdemaris, 04-25-2004 14:57:16
It has the roosamaster DB, I will check for air leaks and look for the mouse turds. It did start hard two times before this last problem. Yes it has over 8000 hrs. Thanks
Russ
04-25-2004 10:13:37
Any diesel system needs a constant supply of CLEAN fuel to the injector pump under pressure and no air in it.
* Remove the glass bowl on the fuel pump and check for water presence. Crank engine over and check for pump pressure.
*Check your fuel filter/s for water also although the glass bowl usually catches all of it.
*Check for ANY looseness or leakage between the fuel tank and the injector pump. Remember, fuel leakage out equals air leakage in.(If you have the glass filter type, the rubber sels on them can deform and cause air to leak in.
* Also, check for fuel leaks between the injection pump and the injectors by VISUAL ONLY!
(diesel can be injected into your skin very easily) This step is doubtful because you would smell raw diesel fuel when it's running.
You'll need to bleed the system as necessary when you mess with any of these areas.If you still havea solid steel line from the tank to the pump, the fitting at the pump usually gets loose and air gets in. Cut it at some point and install a piece of hose between for vibration purposes.
Bob
04-25-2004 09:42:14
Get up close to the injection pump (engine OFF), and have someone cycle the throttle lever from idle to fast, and back. The injection pump has a setscrew that limits the throttle arm travel, to set idle speed. At the idle position of the throttle lever, the setscrew on the pump lever should be touching the stop. If it is not, you have linkage problems.
If the idle stop IS touching, ad the engine will not idle down, you probably have internal pump problems.
Ben
04-25-2004 11:22:11
 Re: Re: 3010 injec. pump in reply to Bob, 04-25-2004 09:42:14
Yes the idle stop is touching. No problem with the linkage. She will not idle down. I am thinking its a pump problem due to age and hours on the tractor.
