JC, you ask, A. - How do you check the level of the transmission/final drive gear oil? I can pour in the recommended amount, but I don't see a plug or level check device similar to what is on the engine casing?...>>> You use a stick from the fill hole.. There is no test level hole.. B. - I didn't fill the first reduction gear sump with engine oil before I closed her all up. I believe that that sump fills with engine oil that runs out of the R.H. main bearing and that the excess oil drains back into the crankcase thru a hole ahead of the 'dam' that is part of the gear cover casting. It will take a while to fill from excess main bearing run-off?..>>> Don�t worry it will fill as the engine runs.. 1. Is there a simple way to fill the sump?...>>> Yes, just pull the top plug on the center of the big tin trans cover & pour the oil in.. You measure it using a stick from the top through that the fill hole.. I don't remember the correct level using a stick as I only use 5 gallons of trans oil in all of mine to keep the trans oil level below the axle housing joints [I will check for the proper oil level tonight & post it here].. OR you can just add the proper amount & mark a stick at that time.. 2. Do I need to fill it?...>>> See above.. I only use 5 gallons in all of mine.. 3. How do you drain that sump during an oil change - I don't think it has a drain plug?...>>> There is an oil drain plug on the bottom of the engine. [email protected]
