70 Diesel belt pully problem
Ghostrider
04-24-2004 19:26:27
Would anyone have a belt pully for a 70 Diesel for sale in the Kentucky area? While we were trying to repair the clutch, a bad thing happened. One of the toggle pins came out. We then had to pull that gear off. That took a big puller! Unfortunately, while freeing up the dogs, one of the lugs broke off right across the top of the pin hole. If we don't find one, we are going to try and weld the pin solid. The toggle dog can still pivot on the pin.
Is the 70 clutch prone to problems? The lug had previously been welded at the base and the sleeve lug had alsp been brazed together. The drive disk and splines were okay(thank goodness).
Clooney
04-26-2004 11:58:09
 Re: 70 Diesel belt pully problem in reply to Ghostrider, 04-24-2004 19:26:27
Ghostrider, Dengler can repair that pulley for you.. They have new machined pivot bosses that they can put on for you..
~If you only broke the top of the pin boss then a build up with cast weld & a little grinding then re-drilling the pin hole should get it up & running again..
[email protected]
buickanddeere
04-25-2004 08:40:34
Dengler's Tractor [513-423-4000 has rebuilt clutch pulleys and all the parts. Even undersize drivers to fit snug on worn crank splines. Clutch work can't be rushed, jammed, forced or be successful while cutting cost/time/effort.
