3010 Gas weep hole
Deer Hunter
04-24-2004 14:26:09
I am looking at a John Deere 3010 gas tractor to buy and it has a antifreeze that comes out of a weep hole in the side of the block. The hole looks like it has been covered with silcone or JB weld and it runs for about 3 inches up and down. The antifreeze just gets the block wet but does not drip after running about 10 minutes. I am wondering if the block is cracked (junk) or if it really is just antifreeze come out the weep hole. The guy is selling it for someone else and he said he didn't know anything about it. Any thought on this. thanks
DON
04-24-2004 14:58:49
 Re: 3010 Gas weep hole in reply to Deer Hunter, 04-24-2004 14:26:09
THOSE WEEP HOLES SHOW YOU A FAILURE OF THE PISTON LINER SEALS. USUALY YOU NEED A NEW SET OF SLEEVES TO SOLVE THE PROBLEM. NOW THAT BLOCK HAS SOME TIME ON IT AND COULD BE ERODEING AS WELL. JUST KEEP THIS IN MIND IF YOU BUY IT. DO NOT PLUG THESE HOLES AS THE ANTI FREEZE CAN GET IN THE OIL AND ANTIFREEZE IN THE OIL IS LIKE SUGAR IN THE GAS TANK. DON
