24T Baler?
Chris Anderson
01-25-2004 22:08:16
I am just getting back into hay work since I just bought my own farm. My question is how does a 24t baler compare to a 336? A 336 is all I used as a kid and the only baler I have been around But they're a little pricey when I have to buy all the equipment for my self. I have a new MF 481 I think it should pull the baler. Any help would be appreciated Thank You
Mark
01-30-2004 10:03:41
 Re: 24T Baler? in reply to Chris Anderson, 01-25-2004 22:08:16
I bail a couple hundred squares a year now that I have a bailer. I went to the auction yard and all the newer 300 series balers were $3000 or so and all bought for Mexican customers. They put them on an 18 wheel flat bet (on end) and ship them from N.Texas to Mexico.
All that was left was a 24T. It was a twine bailer and all the workings and tin were in excellent shape. I paid $700 for it (not auctioned) and used it all of last year without having to replace/fix/repair anything. I did grease it good B4 using.
The previous owner did 2 things right: Knew what a grease gun was and how to use it and kept it in a barn when not in use.....still had pretty good original paint.
The flywheel shears pins if your don't do your bailing right but pins are at the local JD dealer (actually 1/4 x 2" bolts with locking nut in #8 temper)and not too pricey. Besides I am a novice and only paid $700 and only bail a few bails..... what the heck.....so I have to jump off the tractor every once in awhile and put in a new shear pin.
What I learned is to leave it loose. Just run the nut on far enough to engage the locking mechanism on the threads..... ..... ..and don't use el cheapo bolts or you will be hopping off every other bail to replace the pins.
Mark
Paul Oehlke
10-23-2005 21:37:31
 Re: Re: 24T Baler? in reply to Mark, 01-30-2004 10:03:41
Mark's experience with the used 24T reminds me of mine with a new 24T we used during the late 60s and early 70s. Grease 'er up well and keep and carry a few shear pins in the toolbox and you're good to go. We'd have kept the 24T for many more years, except the bale thrower we bolted on left much to be desired. The 24T was a reliable workhorse.
Rodney A Johnson
01-26-2004 13:19:34
Like the others, I have used the 14T, 24T, and 336. The 24T and 336 have the same chamber size and are larger than the 14T (more capacity).
The 24T has a poorer pickup, thus usually you plug the pickup before you can overload the plunger and chamber.
I have not personally plugged the 336, as the pickup system still cannot outfeed the plunger.
336 has a lot less grease points. I believe the plunger on 336 runs on bearings, where as the 24T and 14T just slide steel on steel.
We ran a Ford 4000 (43 hp diesel) on the 24T for many years without any problems with horse power. Even our '52 G could run the baler without problems.
If you can't afford the 336, buy the 24T, I think you will be happy if it isn't worn out completely.
Stuart
01-26-2004 08:09:13
I have used both and a 336 is twice the baler a 24 t is.
They are easier to maintain and safer to. I bale about 15000 bales year the 336 is about 23 years old and it always worked great. one thing you will have to watch out for is that they have a weak hitch. they like to break half way back on the square tubing. About 12 years ago I had the Knotters completey replaced. But you have to remember that I baled alot of hay with this machine to. Generally the older the machine the more they give problems. The 336 will be easier to find parts for. In you case a 24 t will work if you dont bale alot of hay in a year.
John T
01-26-2004 08:07:38
Chris, I have pulled 14T a 24T and a 336 only a little (newest I ever used). The simplest way I could describe the 336 was that it will eat more heavy hay and eat it faster than the older models. If youre not gonna do tons of hay and never in any super rush, a well maintained 24T should do the job for you in my opinion.
John T
John T
01-26-2004 08:02:36
John T
Craig M in NC
01-26-2004 07:26:35
I have a 24T baler that has baled over 3000 bales this year. They are slower than the 336 (I think but am not positive that the plunger strokes per minute is 85 on a 336 and only about 65 on a 24T) but will do a good job if they are well maintained. I just use mine when someone wants square bales and are willing to pick them up out of the field or if someone wants to pay me to bale them. The rest of my hay goes in round bales. I have pulled it with a 25hp compact tractor a couple of times with no problems. Good luck with which ever baler you decide on. One more thing. It is getting to be fairly old. I had to do a dealer search for parts to find a piece for the header this year.
