45B Remove 60 years of caked grease oil dirt
Ben.So.Tex
04-24-2004 09:17:33
I am restoring my fathers first tractor.What is the best way to remove old caked on grease, I have pressure washed it @ HIGH pressure and some of it is still sticking,I am now going to soak it with some diesel to see if that will work. Give me you input. Thanks Ben
Dan
04-25-2004 09:19:18
 Re: 45B Remove 60 years of caked grease oil dirt in reply to Ben.So.Tex, 04-24-2004 09:17:33
I had a lot of that on my 38 G (also my father's tractor). Mostly used a pressure washer on it and some of the de greaser sold at various outlets. Most of it came off and I found stuff on it I didn't even know was there. Have also used some of the spray on de greasers with a wire brush and that seems to do a good job.
F-I-T
04-24-2004 18:43:05
Ben:
Soaking the crud with diesel fuel, followed by a lot of pressure washing works pretty well. If you intend to strip the old paint and repaint it any way, you might try some of the lye gravy mixture. Apply it with a synthetic brush (the lye will ruin natural bristle), keep it damp by misting it now and then, and it will pretty much dissolve the grease and paint. It may take more than one applicaiton in certain areas. I have a recipe on my web site.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
