Distributor for JD Model A
Tony
04-24-2004 06:03:47
Is there any aftermarket companies that make New Distributors for a Model A?
Earl S
04-24-2004 09:32:04
 Re: Distributor for JD Model A in reply to Tony, 04-24-2004 06:03:47
I have some new Wico. email me I would need more info. You could pick up a used Delco at salvage yard convert to electronic would be the best set up.If you get a used Delco and plan on using the stock point-cond set up more than likely the bushing in the dist will need to be replaced ,maybe the advance springs. Hope this helps .Earl
