3020 Charging system problem
WADE
04-23-2004 19:16:59
O.K. fellas, my 24v generator on the '67 3020D was not charging, so I decided to replace the old generator and regulator. I marked every wire before taking off old parts, and went to JD to get replacements. I installed the new gen and reg, reconnected the batteries, polarized the gen, and started her up. Charging light went out at about 6000 rpm and I thought everything was fine. However, when I shut the tractor off and turned the key off, I noticed a "clicking" noise coming from the regulator and relay by the starter. I have checked all connections, even had a "mechanic" look at it and we are still puzzled. He thought the reman generator might be grounding out as there was excessive spark when hooking up batteries. Went to JD to have it tested. The thing works fine.
If anybody has any ideas to fix this and could explain the electrical system to me, it sure would be appreciated. Thanks
Lee
04-24-2004 01:07:15
 Re: 3020 Charging system problem in reply to WADE , 04-23-2004 19:16:59
You are typing a bit too fast to relay the info needed for this kind of problem. 6000? You surely meant 600 RPM, I'll assume so. "Went to JD to have it tested. The thing works fine." I'll assume the 'thing' was the new generator taken off of the tractor and bench tested at a JD dealer. Did they spin it up and measured the correct voltages on it and the amps that it was making? Or did they just put a multimeter on it and say it wasn't shorted? Big difference between those two 'tests', we'll need to know which one it was and the full results of either.
Generator may be good but the regulator may have some stuck points? They can get welded shut when polarized improperly or when there is a huge load (run down batteries) placed on the 'new' generator. With the belt off does the generator run by itself or 'motor' when the batteries are hooked up?
I'll assume the 'relay by the starter' that is clicking is the starter solenoid? It should not be doing that and indicates that it might be shot? Or miswired? Or both? Possibly a pre-existing problem to the 'new' generator?
This appears to be several problems all trying to get fixed with one go. Is there a battery drain or sparks when the generator is not connected? If so, find the drain and fix that, perhaps the other problems are non-existant after fixing that.
Wiring explainations for 3020s are not possible. Our hard start problem turned out to be an open winding in the starter solenoid which was fixed with bit of solder and a wire splice internally. But the fuel gauge and idiot lights still work only when they want to despite extreme attempts at grounding the instrument panel and/or any other thing we can think of. Both gauge and/or lights can be full on when the tractor is off, off when the tractor is on, working fine, not working at all or any combination thereof at any time. It's not possible to explain that. We requested a wiring diragram from our JD dealer, he supplied us with three that showed parts of ours on all three but not one of the three was ours totally so we still don't know what we got or where to look for a solution. Only thing we didn't try on it was a Ouija board.
WADE
04-24-2004 06:46:08
 Re: Re: 3020 Charging system problem in reply to Lee, 04-24-2004 01:07:15
Sorry, Lee, I'm not a mechanic.
I believe the clicking noise is a circuit breaker tripping. There are two of them mounted off the starter.
The generator does want to spin momentarily (until the ciruit breaker trips).
Yes, I meant 600 rpm. Sorry for the mistake.
There was no previous battery drain.
How can I test the generator for grounding with a multimeter?
Lee
04-25-2004 03:50:55
 Re: Re: Re: 3020 Charging system problem in reply to WADE , 04-24-2004 06:46:08
As Bob said if the generator wants to motor at all you've got regulator points welded or stuck.
You probably won't have any drain then if you tear into the regulator and fix that. Put a battery charger on those batteries so that the next time you fire it up the generator doesn't have to smoke the regulator's points quite so hard. This may have been the only thing you didn't do right in the very first place.
You really can't test the generator with a multimeter for other than a completely melted down armature and your eyes and nose are just as good for that test. A bad sign to look for is a ring of solder slung out from the commutator on the inside of the case. Most generators with this symptom have a shorted armature. Other than this 'test' the only other acceptable test is to place the armature on what's called a growler. This device is plugged into 120 volts and looks like the insides of a buzz box welder. A hacksaw blade is then placed on the top of the armature and the armature is placed onto the growler and rotated. The magnetic fields created between the growler and the armature affect the hacksaw blade such that a good operator can tell if the armature is shorted or not. Unless the windings themselves make electrical contact with the steel of the armature (shorted out) there is little a multimeter can tell you and that simple test isn't worth much at all when the armature does pass it. You would do that by placing one lead on the copper commutator and the other on the bearing surface and look for a connection between the two. If you have a connection there then you've got a bad armature. This would have to be done with the armature out of the generator's case. But such a beast wouldn't even try to 'motor' so I'm sure that's not the problem.
Bob
04-24-2004 09:39:17
Wade,
If your generator is trying to spin until the breaker trips, you have a bad voltage regulator with the "cutout" points (the heaviest set of points) welded together, OR you have something wired wrong. If the contacts can be separated, you might want to try to lightly file them with a point file, make sure all your wiring is correct, polarize the system, and try it again.
For that system to work properly, both batteries MUST be connected properly, AND both battery cables must be properly connected at the starter, AND both wires that supply current to the tractor harness through the circuit breakers MUST be connected properly at the starter, AND the generator and regulator must be connected properly, AND the system must be properly polarized before initial startup of the engine.
All this is child's play for someone with experience on this system, but a nighmare for the inexperienced!
I have some diagrams that might help, email me direct, if interested. Monday would be the soonest I could email them.
