420 W Final Drive disassembly
Henry J
04-23-2004 06:50:21
ARRRRR RRGGGGG
Every time I think I am out of the woods another ton of bricks falls on my head.
In the process of "hopefully" final disassembly on the restoration, I have been chasing a rattling noise in 5th gear. There is a lot of history and under the tree repairs I found on this ole girl.
Anyway on final close scrutiny, it is apparent that one of the final drives have been trashed in the past and not repaired properly. The large gear has a wobble from side to side of 1/8 of an inch. You can see that the gear has been slid to the side off of the hub.
I don't have all the snazzy tools that the book shows and a 4 pound hammer is not gonna knock that axel loose.
Have you folks done a make shift puller like chain and a bottle jack to pull on the two bolts/threaded stock that go into the large gear.
I am thinking about trying to rig it that way while the budget recovers from buying trans bearings lol.
Any suggestions would be appreciated.
Thanx
Dave - Ia
04-24-2004 11:50:14
 Re: 420 W Final Drive disassembly in reply to Henry J, 04-23-2004 06:50:21
Henry J. I think I am going to have the same problem you are working on. I thought I could replace axil seals and tighten up the bearings. It worked on the first side, but not enough shims on the second. As to pulling the bull gear I had planned on using a small bottle jack with a plate attatched to ready rod screwed into the gear. I have no idea how hard that bull gear is to pull. If it is half as difficult as the hubs, it might take awhile. Post an update when you get it apart.
buickanddeere
04-23-2004 07:41:00
The bullgears/rear axles from the 1010 with the inboard finals will bolt right on. The drawbar attachment is a little different but that's all. Finals from a 1010 past 31,001 are 15% or so slower and would be my 1st choice. I have a spare pair in the barn as wish we had put them on the 435 when it was apart. If the ring and pinion is done, the beefy R&P from a 1010 pre 31,000 bolts right in. I think the slower 6/32 ratio are still in stock brand new. Wish we had put them in the 435 as well. Didn't have it figured out at the time.
