B JD Flywheel????
B JDfarmer
04-22-2004 19:18:35
I recently bought a 1948 b on an auction. The flywheel is cracked around the clamp that holds it on. Is this a problem?
Clooney
04-23-2004 03:51:58
 Re: B JD Flywheel???? in reply to B JDfarmer, 04-22-2004 19:18:35
B JDfarmer, it's a problem if it decides to come loose at a later time.. You don't want to take any chance of it running with a loose flywheel as the crankshaft could become damaged from the flywheel hammering around..
~Those old B flywheels are only around $75.00-$100.00 or so & having yours welded would probably cost nearly as much so just call around to a few tractor scrap yards & see what�s available.. There should be a casting number on yours so write that number down & give that number to the parts yard guy..
[email protected]
Mike
04-22-2004 19:23:22
Yes, that's not good
