#8 or #9 mower ?
Craig
04-22-2004 18:29:00
Which one will attach to my 630 3 point?
Which is a better mower?
Got one for sale?
Omaha, NE
fixerupper
04-23-2004 06:42:09
 Re: #8 or #9 mower ? in reply to Craig, 04-22-2004 18:29:00
We had a #9 that we put on our 630 for about 20 years. It was really nice once it was on the tractor but it was a finger pinching #%$#@ to put on. It clamps to the three point arms of the tractor to make it ridgid and getting the clamp blocks in place is the hard part. I think I remember spacing the elephant ears out to take care of the sideways swing.I liked it for mowing ditches because I could drive into or out of the ditch without the worrying about the PTO or tail wheel. If you do get a #9 put your top link in the least sensitive (top) position or else the spring that lifts the bar will react with the load-and-depth control on the tractor and it will be forever bouncing up and down. If you are going to be mowing on fairly flat terrain I would recommend the #8 but if you are mowing in rough terrain the one without the tail wheel (#9) might be a little better.
Craig
04-22-2004 20:49:15
Thanks! Any advantage to a tail wheel?
Jake
04-22-2004 21:20:58
 Re: Re: #8 or #9 mower ? in reply to Craig, 04-22-2004 20:49:15
It keeps the back end of the mower from draging on the ground, heh heh!! Well, the tail wheel is required for the that style mower. The semi-mounted mower was designed to work with tractors that did not have a 3-pt hitch. The tractor holds up the front of the mower frame, the tail wheel holds up the back of the mower frame. Remember,you can use a No.8 mower with your tractor if you can find the correct brackts to go along with it. See Ebay Item number 3801156333 at this URL for a picture of the brackets to connect a No.8 or 38 mower to your tractor....
Link
The full 3-pt hitch mount would probably be easier to manuver in and out of certain areas. However I have not used a 3-pt mounted mower so I can not say for sure.
Jake
04-22-2004 19:20:56
A No.9 Mower is the 3 point hitch version. A No.8 is the semi-mounted type, it attaches to a pair of brackets that are first bolted to the "elephant ears" of your 3-pt hitch and it also uses a tail wheel like the No.5 mower.
