316 Shut of Problem
Fred
04-22-2004 17:52:52
With my 316 running, if I move the hydrostatic out of the netural position,(either forward or reverse),the tractor shuts off. The same thing also happens if I turn the switch on to start the mower deck.If anyone has a idea, I would be grateful.
G-MAN
04-22-2004 18:02:01
 Re: 316 Shut of Problem in reply to Fred, 04-22-2004 17:52:52
I'm not a mower guru, but it sounds like a seat switch problem to me. There is a switch located in the seat that tells the safety circuits that there is an operator on the mower. If it's bad, it doesn't know you're there. Try installing (temporarily) a jumper wire across the harness in place of the switch and see what happens. I say "temporarily" because that is a safety device, and it's not smart to permanently bypass them.
Mark57-420
04-23-2004 06:46:47
 Re: Re: 316 Shut of Problem in reply to G-MAN, 04-22-2004 18:02:01
Ditto! I had the exact same problem with my 318 last year. I'm 99% certain that is the problem, but be careful that it isn't a broken wire instead of the switch. If it's a wire, jumping the switch won't fix it. You'll have to trace the wiring back and look for a break.
