How much oil?
mike
04-22-2004 17:31:23
I just bought a 52 B, and I am going through everything and I was told by the previous owner that it took about 5 gal. to fill the oil. Is this correct? I do not want to overfill or underfill. Thanks in advance
James
04-22-2004 17:50:53
 Re: How much oil? in reply to mike, 04-22-2004 17:31:23
Sir ,you need to order you a manual SM2004. It takes 7 Qts. of oil in the crankcase . You need to allow for filter and clutch case so when it runs a little and then drips out of the cock when you shut it off it is full. Hope this helps
Steven
04-22-2004 17:45:29
Engine crankcase 7 quarts. Trans & Diff 4 1/2 gallons. Cooling system 7 gallons.
