116H no gas
Dave F
04-22-2004 17:01:11
I have a 116h that isn't pumping gas to the carb. Tractor ran before it sat for a year and half.Will crank and run if you put a little fuel in carb.The fuel pump is electric and does work if you run 12 volt to it direct. My question is does the fuel pump switching on go thru the ignition switch to turn on and off? (switching ground) Any help would be great and Thanks in advance.
Chris
04-22-2004 20:14:42
 Re: 116H no gas in reply to Dave F, 04-22-2004 17:01:11
It should come on when you turn the switch. Is it original or is it an autozone ad on? You may be able to find a wiring diagram from someone on this site or the garden tractor website.
Thanks
05-02-2004 19:37:22
 Re: Re: 116H no gas in reply to Chris, 04-22-2004 20:14:42
Thanks Chris, got a new switch and that took care of it.
