Congratulations Scott, If the pipe aint too rusty, its cleaned up well n flux used if needed, and youre a good welder, you may be able to braze it up. Ive had muffler shops fabricate me a steel pipe Ive used as water pipes in the past. On 6 volt systems, you first need a well charged good heavy rated battery (give her a good charge n try it) and I prefer to use 00 Gauge Battery and Starter and Ground cables. Make sure shes well charged, no low cells or gray or milky cells, have a battery shop load test it if any doubt, or use a known good replacement see what happens. You may try a new ground connection on the main frame or closer to the starter if its grounded now via a rusty seat or battery box. Remove, clean n wire brush, and re attach ALL starter n battery n ground cables n check the ends n cables and see what happens. If its a mechanical push type switch instead of a solenoid, they can be burned or carboned or those type starter posts can be burned or pitted or carboned over under that switch also. Its easy to see either problem if its a push mechanical switch and you remove it. If the starter has that classic burned electrical smell, it may be bad. Of course, the starter cant be stuck or jamming into the flywheel causing the problem, if so, loosen the starter and/or rock the flywheel and see what happens. When the starters engaged, look for hot spots or any sizzling connections or smoke. If you have lights or a voltmeter, have them on and engage the starter and see if the battery voltage drops or lights dim dramatically. If so, the starter switch (or solenoid) is working but the starter may be bad or have a dragging armature etc. If theres no drastic battery voltage drop or light dimming, the switch or solenoid or starter post may be the culprit (not providing a good connection and starter dont draw needed current). Is it a mag or distributor ignition????? A good working mag with a good strong spring would still yield a good sprak at slowwwww ww crankign speeds, while a marginal or weak distributor ignition can have a weak spark if a poor start system drags the battery voltage down excessively. What you have????? ???? Post back or e mail [email protected] any info or other questions. Good Luck n God Bless John T
