730D Power Steering
Steve
04-22-2004 13:02:08
Can anyone tell me a good way to get the plug out of the hood (to check, and or, add, power steering fluid) without scratching the paint?
Dick
04-23-2004 04:50:43
 Re: 730D Power Steering in reply to Steve, 04-22-2004 13:02:08
Not sure about the 730 but on an 830 it is probably easier to just take the hood off to get to that fill pipe.
Clooney
04-23-2004 03:44:30
Steve, I don't know about the 730 but I had the same problem on a 520 & was able to put masking tape all around [& under the edge of] the plug then slide a piece of thin Mylar plastic under the cap edge, then use a long thin bladed screwdriver between the Mylar & the hood.. By using a paint stick as a fulcrum I was able to pry the cap up all the way around without damage to either the hood or cap..
[email protected]
John T
04-22-2004 14:55:05
If it wasnt in too tight, one of those suction cup tools or the rubber suction cup type tool we use to lap in valves may do it, but I have my doubts. The small vacuum dent pullers which attach then engage by drawing a vacuum stick real well, then maybe a thin non metallic edge instead of a pocket knife under a raised edge??? Sounds like a good place for some lithium grease or teflon coating or something similar to prevent rust and sticking. Trouble may be if she dont pop in tight you couild loose the plug grrrrr rrr.
Take care
John T
Tyler-MO
04-22-2004 13:30:24
There is really none. I would take a pocket knife and use the edge to slide under the plug and then pull up instead of pry. You might be able to even aviod scratching the paint. So what if you do, just to to your JD dealer and get a green paint pen. They pop out easy once you get an edge on them. Good luck
